eQlipse wrote:Whew!
I'm hoping this will be a much cheaper fix & no additional problems have been created. Thanks for that clarification Chally!I think I'd better still get it checked out & maybe flush the cooling system.
We still need to find out teh oriigninal cause of the problem.
Did over pressure from boiling coolant make the housing crack/come off?
Could be.
If so and <if> the engine still shows good compression it will need the follwoing.
New knock sensors whch are certainly shot at this point as they get quickly ruined by an overheat and It sounds like you had a couple+ bad ones.
New Tstat, new radiator, triple flush teh cooling system with a combination of a flush chemical and distilled water.
Then refill with 70% distilled (or deionized) water, 1 bottle redline water wetter (about 3.5 %), rest antifreeze.
Be <sure> to check your water pump as well, as those often leak when bad.
Fred...
