part ID what is this?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
pejsa s-13
Car: 91 HardBody, 85 720
its located under the front of the carb. just wondering what it is, it's importance?
i took it off the truck seems to run fine it actually kinda solve a problem i was having with the truck sputtering after i shut it off..
PEZi
AB valve....
mine is gone if that matters
it stands for 'anti backfire'
pejsa s-13
is it a smog required object?
PEZi
probably...
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
It sometimes causes post ignition depending on your timimg. And yes its a smog requirement as it recirculates fumes back into the manifold.
PEZi
yeah... having it gone causes a little bit of 'popping' for me on decel (completely off the gas) around the 1,250-1,500 RPM range... if i throw it in neutral before before 1,500 its all good tho
no different then those damn SRT-4's
Return to “Datsun 720”
