Part from FWD CA18de
khatedral
Car: 240sx - CA18det
Hello and im new here. an I been trying to search a good reading about this matter but the only readings that i been found is how to convert fwd to rwd.
I have a 240sx with a CA18det swap and I would like to know if parts from a FWD CA18de will fit in the RWD.
Right now I found a good deal to buy a complete FWD CA18de engine and I would like to have some spare parts in case something brake in my engine.
Well the most important question here is if i can use the head from a FWD and place it on a RWD, the valves in my RWD, some are bad, also to know if the crankshaft if the same, because the FWD crankshaft is std like brand new and my RWD already is running .50mm bearings.
Any advise or help would be very appreciate. thanks
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
I have ca18de pistons and head with a det block and crank/rods. Also used ca18de rebuild kit for bearings/gaskets, 88 pulsars are useful as part bins :) (and i drive one anyway)
khatedral
Thank for the info so it looks i can use a lot of parts from FWD ca18de to my RWD CA18det
CaDet s13
Car: S13 240sx
Powered by Ca18Det
There is alot of useful info in the faq sticky in this section. Including crossover parts etc. Just about anything you might need to know is in there thanks to our wonderful moderators on the ca series motor
