parking lights quit working!
northups13
Car: 1989 s13 ka24de
i cant figure out why my taillights or my front parking lights dont work, when still my headlights and brakelights work. aswell as turn signals. there was a blown fuse i replaced, im pretty sure it was my audio. i also replaced the switch and they still wont work. no tail lights sucks, i need help with this issue bad, its killin me. is there a fuseable link somewhere that could be blown? HELP
Modified by northups13 at 5:47 PM 12/24/2007
Modified by northups13 at 5:49 PM 12/24/2007
northups13
northups13 wrote:ive got head lights and brake lights, but no tails or parking. turn signals work and the only fuse that was blown was the audio. i replaced the whole turn signal switch itself and they still wont work! anyone had this issuse also?
someone help me with this if they can please.
Masterkillalw
Car: 89 240sx HB
PLEASE!! Someone help me. I have the same problem. No tail lights, no cluster lights, no front lights. Have headlights, brake lights and turn signals.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
your going to have to pin this one out...you start in the rear of the vehicle and find the access panel for your rinning lights...turn on the lights with the car running and chech with a volt meeter if there gettin any power...if no...back check any wiring that might have been done recently..including said switch installd..post again what ya find.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
sometimes when I take out my cluster I forget to plug back the harness that goes into the dimmer switch and my cluster lights don't work. Never checked if my parking lights worked. Right now I just noticed that MY parking lights don't work! my cluster lights isn't working either. Don't remember if i plugged in that switch though..... will check when I get the chance.
maj Andres
It's plugged in. will check fuses later
ZAKU
Car: 1995 240SX
I'm not too familiar with 240sx wiring just yet, but I would assume there's some sort of running light relay like on my old car.
If you have a service manual try looking for any lighting related relays and replace them.
maj Andres
Well I had a blown fuse (10a) as soon as I popped in a fresh one IT BLEW! bad ground? this sucks
maj Andres
Found the problem, it was the way I wired my radio. Fixed the wiring and the fuse stopped blowing.
