parking light problem
kurama240sx
Car: 93240sx coupe
ok i have a 92 coupe and i recently installed a new alt and i think i may have blown the parking light fuse. my headlights, brake lights and dome light work. I cant find it nor do i know where it is and yes i SEARCHed plus check to see it i had any bad bulbs and i did and replaced them please help
ths may be my first post but i been reading here for a long time lol so no welcome to the forum
onosqv
Car: '92 240sx Vert
did u check ur fuses? there's one by the driver kick side panel...
kurama240sx
Car: 93240sx coupe
yea i did ... didnt see it in there or the fuse box next to the battery but ill check again
onosqv
Car: '92 240sx Vert
well the parking/brake/dome light fuse is in there for sure...
The headlights... check to make sure they aren't blown. Might as well check every fuse, haha.
***EDIT: just noticed that you said those things are working & just the parking light isn't. So yea, the parking light fuse is definately in the kick panel.
Once you find out if it's blown or not, you have to check every bulb - sidemarker, turn, and rear lights, one bulb out usually causes a chain effect - like old xmas tree lights.
