Feature? In as much as it's telling you there's a problem, yes. Is it a problem? Yes, but what?coopab wrote:My wife's '09 parking brake warning light/chime is driving her crazy. It won't stay "off" even after lifting it with one's foot. While out with her recently I checked the owner's manual and checked the brake fluid to make sure it wasn't low. Brake fluid was where it should be so I recapped the reservoir and after that the light/chime stayed off for several days until she bumped her parking brake pedal while getting into the car. Light on/annoying chime returned.
Is this a "feature" or a problem?
coopab
the emergency/parking brake doesn't run on brake fluid. its an independent, cable system. so no need to check the brake fluid. Furthermore: the E-brakes/Parking Brakes ONLY apply the rear calipers. Its not an anti-lock (abs) system either. The Parking/E-Brake do not influence the front calipers at all. SO PLEASE NEVER STEP ON THAT PEDAL, AS YOU WILL THROW YOURSELF, INTO A FISHTAIL.coopab wrote:My wife's '09 parking brake warning light/chime is driving her crazy. It won't stay "off" even after lifting it with one's foot. While out with her recently I checked the owner's manual and checked the brake fluid to make sure it wasn't low. Brake fluid was where it should be so I recapped the reservoir and after that the light/chime stayed off for several days until she bumped her parking brake pedal while getting into the car. Light on/annoying chime returned.
coopab
User error PEBEBAS (Problem Exists Between Emergency Brake And Seat)ImStricken wrote:if not- the fault lies with YOU. Someone must be accidentally applying it while getting in or out of the vehicle.
nissan often ignites the SLIP light when the pads are worn/fluid is low. how many miles do you have on the pads? what color was your brake fluid?coopab wrote:all of the above makes perfect sense. What mystefied me is what the owner's manual says. I don't have it with me since wifey is at work, but there seemed to be an implication that somehow the hydraulic system IS related. I guess the light must serve dual purposes: 1) warning that the e-brake is on, and 2) brake fluid is low due to leakage, worn out brake pads, etc. Of course, "take it to the dealer and have them check it" is always the ultimate solution.
So, next question is: Does anyone have any actual experience in adjusting or replacing the e-brake switch.
No No Nominibus4 wrote:Electrical tape over warning light='s problem solved
The problem still exists, although we've been able to keep the light/chime off by gently touching the pkg. brake pedal until it stays OFF for most of the time. However a slight touch of the pedal, hard to avoid completely, will make the light come on and the chime start dinging.minibus4 wrote:Electrical tape over warning light='s problem solved
There is, however I'd recommend looking at what's happening with that switch and see if it's a simple fix.ImStricken wrote:see if there is a sensor/wire to the e-brake pedal. you might just be able to disconnect it
The parking brake is definitely DISengaged. The only problem centers around the nuisance of having the parking brake warning light and chime on. We can get it to stay off for extended periods of time by gently pushing down on the pedal (not even close to engaging the parking brake) until the light and chime go off and stay off.sprocket wrote:There is, however I'd recommend looking at what's happening with that switch and see if it's a simple fix.ImStricken wrote:see if there is a sensor/wire to the e-brake pedal. you might just be able to disconnect it
Last thing you wants is to have parking brake engaged by accident and drive for a prolonged period with it that way.
