rgw2435 wrote:thank you for your reply-
i dont know if under dash is the usual parking brake location of the majority of the trucks manufactured-i assume most were automatics and they had the transmission mount option- the 5 spd seems to be a cost item on the bill of sale-
i will look at the rock auto web site and see what they have available -
here's hoping
I had a '93 4cyl AT 2wd,, and the parking brake was under the dash to the right of the Steering Column, as you describe.
You'll probably need to order by VIN # to get the correct cable length.
This you may allready know: The parking brake is adjusted while stopped, by pulling the parking brake handle ~ out & In ~ a few time's, without the brake pedal being applied, or at least that's the way it was on my '93.
Good Luck
