Hi,Is parking brake using the same pads (2002 Q45) as the main brake or is it a different set of pads/shoes on internal drum?
In other words, will a weaker parking brake become stronger after regular rear pads change? Or the parking brake should be adjusted independently as it is not affected at all by a state of the main pads (as it is the case in most other cars)?
BTW, are there any service manuals on the market for this car? I'm using http://www.alldata.com, but they are not very detailed in many sections..thanks
