qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Mar 27, 2004 3:42 pm
blinking security light- most likely the hood or trunk plunger switch needs replacement,check all door switches also,but if that was the problem,the interior lamps would most likely remain on.the light is blinking because it thinks the hood-trunk-door is open.hope this helps
