Parking Brake light?
jimmitoman
The brake light in the instrument panel keeps flickering on and off,so I disconnected the switch from the hand brake itself, but the light still flickers. Does any know where the wire for that dash light is? Does anyone have this problem? 1992 240sx(ka motor)
rudy543us
Car: 89 240 SX
Hey Jimmitoman
Read below this is what I tryed and after reading the resolutions for other people with our issue, I think I will check my Brake and clutch fluid levels and sensors, that seems to be every ones problem.Good luck
--I have a problem with, what I think is a parking brake 1989 240sx. I I check the parking brake sensor buy, removing the plug, shorting the plug which made the lights dimm "not good" and then I check the sensor on the resovoir, by shorting the leads out which made zero changesI did take a volt meter to both switchs and found zero volts.I was wondering was there any where sensors for brakes that year, it is Not antilock at least I do not see the fance box with all the lines comming out of it.
HelpThank you.
Defiant
Car: 1997 J30
Yeh. Top-up your master cylinder. Your fluid's low.
kevinarich
Car: S14
if your fluid is low maybe your pads are low. maybe its your cars idiot light for people who dont maintain thier cars.
rudy543us
Car: 89 240 SX
1989 240sx
There is no sensor attached to the clutch master cyclinder or is there a presure switch near the slave on the transmission?
Where the hell is the switch for the parking brake light, I could not find it near the hand lever.
Defiant
Car: 1997 J30
Clutch? No, BRAKE fluid.
rudy543us
Car: 89 240 SX
What the hell does that mean? I've looked at the cluth and brake fluid/sensor now where is the parking brake sensor/switch located.
Thank youRudy
kevinarich
Car: S14
at the base of the parking brake handle
rudy543us
Car: 89 240 SX
dude I looked there this thing is weird, 89 240sx.did they ever put it under neath the car instead?
kevinarich
Car: S14
Directly under the handle is the wire. I just looked in the fsm. On the front at the base under the handle
ugadawg
Car: 1997 Nissan 240SX SE/LE
Your brake fluid is most likely low. Check it first before you do anything else.
