Parking Brake light stays on!
UnbelievabLS1
Car: Racing
Usually, when you release the emergency brake handle, the little brake light on the dash goes off. Well, for some reason, the one in my 93' 240 does not. What would be the cause of this, and how can I fix it?
Tnanks! :cool:
quiksilvia
Car: 95 s14 se
mine does the same thing, i havent fixed it, but take off the ebrake boot and play with the sensor and or adjust some things so that it engages the sensor.
UnbelievabLS1
Car: Racing
Thanks alot Brandon, I'll try that. ;)
Touchdown038
Car: Computers, cars, sports
There is a sensor inside your brake master cylinder that lights up the brake light when there is low fluid inside the reservoir. Check your fluid level.
UnbelievabLS1
Car: Racing
Touchdown038 wrote:There is a sensor inside your brake master cylinder that lights up the brake light when there is low fluid inside the reservoir. Check your fluid level.
You sir, rock!! :ylsuper Thank you. :cool:
Touchdown038
UnbelievabLS1 wrote:You sir, rock!! :ylsuper Thank you. :cool:
Why thank you. :)
quiksilvia
Car: 95 s14 se
ill check that as well, gracias
Magnes
Car: '89 240SX, done up with a chrome-plated ground wire to the engine.
RTFM
