Parking brake light on
asnorton44
Car: 2001 Infiniti QX4
This morning when I was driving to work the parking brake light started to flicker then a few minutes later it stayed on. Seems to start flickering when I hit bumps. I parked and engaged the brake then disengaged it and the light went off only to come back on down the road.
Is this something I should worry about? Any ideas?
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
When you barely lift your parking brake lever, does the light come on? Or does it only come on after the first one or two clicks of the parking brake lever?
If it's coming on as soon as you touch the lever, the parking brake could just need an adjustment: page BR-31 of http://www.nicoclub.com/FSM/pathfinder/2001/br.pdf
yeldogt
Car: 02 Pathfinder 4X LE (X2)
Check the brake fluid level.
When you hit a bump and the fluid is low the sensor trips and turns on the light.
How long since the pads were replaced?
asnorton44
yeldogt wrote:Check the brake fluid level.
Had my brakes done a few months ago. Also I noticed that when I slightly move the lever it affects the light. Ill try the adjustment procedure.
fueler
Car: 2 Nissan's
2 BMW's
$20 says low fluid level.
