Post by dmetheny55 » https://forums.nicoclub.com/dmetheny55-u295982.html Sat May 02, 2020 5:21 pm
Post by Rogue One » https://forums.nicoclub.com/rogue-one-u185971.html Sat May 02, 2020 6:23 pm
The only inputs for the red BRAKE light on the Altima are the low fluid sensor in the brake fluid reservoir, or the E-brake.
Assuming the e-brake is disengaged, check the fluid level again. Even though it may be full, some cars need a little extra to keep the light off.
Keep in mind, brake fluid levels drop only due to a leak, or pad wear. In a perfect world, as all 4 pads wear, the brake fluid level will drop and activate the light at some point before the pads are totally worn out. It rarely happens though. To make a long story short, if your brake fluid level was low before you topped off...check your pads as they may be wearing the end of their life. Cheaper to replace before they start scoring the rotors.
Return to “4th Generation Altima Sedan (2007-2012)”
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
