Touchdown038 wrote:Looking at the pads is different than changing them, no?
Is it even something worth discussing? I said change the pads, because most likely on a properly fucntioning car, when the brake light comes on, it means change your brake pads. Obviously when you LOOK and see they don't need changing, then leave em alone and look elsewhere for the problem/solution.
P00t, I understand what you told him, I was just being sarcastic. Regardless, the first suggestion to someone's brake light comming on should refer to the brake pads.
Okay guys? Lets go do some stuff or something now. :pface
