loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Nov 29, 2009 4:53 pm
I'm assuming that you have checked the front parking brake cable connection to the main parking brake lever.
Make sure the parking brake cable is connected properly to the rear brake assembly (lever, spring, etc.). Trace the parking cable from the rear going forward. If Ok and the parking brake cables are intact (1 front, 2 rear), then the rear cables could have been disconnected from the front cable (joint is at the center of the undercarriage).
