Parking Brake Cable
lansee
HOW DO I EXPOSE THE ADJUSTMENT IN THE PARKING BRAKE CABLE, JUST REPLACED REAR BRAKE PADS AND NEED TO TIGHTEN CABLE, THANK YOU.:confused:
ricebike
2002 Quest
2005 Altima
don't you just reattach the cable & when everything's together, step on the brake n pull up on the parking brake lever. the screw adjusters on the calipers would adjust the pads to the rotors.
180fan
Car: 89 fastback
On your ebrake on the inside of the cabin. On the lever you'll see a small hole on the rubber housing of the ebrake under the lever. Stick a 8mm socket in there and tighten it that way. I think oem number of clicks is 6-8.
