Park neutral error and reverse lights out
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Great White Versa
Car: 2007 Nissan Versa S HB 6sp
Hey guys, I've had an intermittent park-nuetral error code for a while on my 07 s manual hatch. Some time last week it went from a single park-nuetral to repeating that error. About at the same time my reverse lights stopped working (and possibly the break lights, though they may have burnt out, i'll test it today).
I found online a post that mentions a reverse switch on the transmission but don't know how to find it.
Reverse lamp switch is located on the top side of the trans
How do I find that switch so that I can test it? What are the target specs for the test?
*edit*
I pulled the light harness out and replaced all of the bulbs that weren't lighting up but the reverse lights still don't work. I checked the fuse that I think is responsible for the lighting (the 1st from the left on the second row in the fuse box under the steering column) and it looks fine.
*end edit*
What other issues might be causing this?
Thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Does your car not have a factory warranty still? If not take a gander at the service manual: http://www.nicoclub.com/FSM/versa/2007/hatch/
Great White Versa
No, or at least the dealership wanted to charge me $125 to 'diagnose the code' even though I had already determined that...
anyway, I ended up ordering a new switch and swapped it out myself. That was the beginning of June and everything is happy now.
Return to “Versa Technical Discussions”
