pedsemdoc »
https://forums.nicoclub.com/pedsemdoc-u162296.html
Mon Sep 26, 2016 6:53 pm
Can't really tell what's going on...blinking intermittently of one parking light on one side, then going out. Then the same for the other side?
are you using cheap LEDs are more expensive ones? if you don't have the bulb seated correctly in the base, you can short stuff out or have lights that flicker or go out..does the wiring to the parking light look frayed or worn?
