Park lights don't flash on locking with key fob
reliant
On my 94 Q the parking lights sometimes do not flash when I lock the car with the key fob. The car does lock but I keep having to walk back to my car to see if it is really locked since the parking lights don't always flash like they use to. This situation will occur for a few times then be ok again later. Any body have this issue before and know the solution?
Thanks in advance for any help
Dan L.
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
You might just need a new battery for your key fob. Just a thought.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I have the same issue, somewhat. I can hear the doors lock, but no flash. The lights do flash wiht the horn, when the alarm goes off.
I have found that the rear driver's door is not locking. Neither does the window roll down, from the console switch. I think my problem is a loose connection, in the door, sonce the window rolls up and down with the door switch.
You might try all the doors, to see if one is hanging up.
BIONICQ45
That is odd Jeff, my LR door fails to lock at time also which prevents the lights from blinking when the fob is used. The window rolls down with no problem though.
