paraut vs deatchwerks fuel injectors
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
I changed my injector o rings last nite for the hell of it.3 of them the plastics tips by the nozzle were broke off on a few of them.I got everything back in and it runs good but at idle it is rough as hell.Doesn't drop rpms or anything but it is sort of shakey.I'm thinking they are all due for a replacement.I can get deatschwerks for around the same price as some oem paraut but haven't been familier with either brand.I know deatschwerks are known to be good.I can charge the oem ones at work and pay them off later instead of buying the deatschwerks on the plastic.Any opinions.
slyedog240sx
I think i am running lean.There is this super hot burnt smell now.I now have a miss at no load then it kicks in once a load is put on.It has to be injector related since this problem was non existant untill i did the o rings.I know found that #3 is at 45ohms which is way too high.
Modified by slyedog240sx at 1:43 PM 4/18/2009
