Parasitic pull let me pick ur brain....
bades
Alrighty guys Im on vacation 7 hours from my home.... needless to say I didnt bring alot of my tools...Ive been searching for the answer but havent been able to figure it out so Im askin you guys....
ok heres the deal, i have an rb swapped rps13. I have a huge pull from sumwhere. narrowed it down.
I have found that when ever i pull the window fuse labeled ENG CONT (FL25A) in the passenger side of the engine bay (chasis panel)the pull goes away. So sumthing attached to that fuse is shorting out.
So heres my question..... What is attached to this fuse??? What does it control??? And is it needed for safe operation???? Any help would be greatly appreciated.... thnx n advance fellas....
240z4u
Car: '95 Nissan 240SX
Sorry dude, misread the post.
Modified by 240z4u at 7:01 AM 5/27/2009
Joe
240z4u wrote:This thread belongs in the tech areas, not the RB forums. Doubt anyone here will help.
um he has a RB swapped S chassis. this is a tech forum.
this is the exact place this thread needs to be.
bades, pull it. see if the car runs. if it runs and drives its not necessary for operation lol
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
It is cake if you already know what circuit it is on. Look up the FSM for the S13 and go to the wiring diagram for that window switch.
Assuming the wiring is not shorting, I'm going to say the window motor has crapped out.
bades
hey guys i got her figured out... the fuseable link ran power to the ecu.. kinda needed lol.... the pull was very slight after further investigation... just the pull needed to power the ecu.... cum to find out my battery was defective again!!! 2nd one in 3 months now.... but all is fixed... thnx again guys...
240z4u
Oh christ, sorry dude. I misread the post and thought you said you pulled the fuse for the windows and the draw stopped LOL.
Good work finding the problem, time for a better quality battery I suspect.
Evan
