Alright so I've had the problem for awhile now. Never did really fix it. I let it sit over night and my battery is almost dead. Engine cranks real slow until it can't. Now i got the car in June 2009 off my dad, we traded vehicles a truck for a car. My dad took it to Nissan for this problem: 5 batteries and 4 altenators later, they still could not find the problem. So I just dealt with it. Then one day I found out the light in my back hatch never went off, so i checked the switch and found out that when I close the hatch it never pushes the spring down to turn the light off. So I unplugged it. Fixed the draw for a bit. Then the car would die in Eight hours. I put another altenator in it as well on nissan's dime. Still under their warranty at the time. And had to put another battery in after so many constant drains. So 6 batteries now and 5 altenators. And now again its draining.
So here Im going to start to look into this problem again. I have audio equipment in my car so I started by testing it first. Charged my battery up, disconnected audio and let sit over night. Battery Drained. So I can rule out my subs, thank god! Now its time to find the actual draw. Now every time I have done this, I have found that the altenator seems to be causing the draw, so Im going to test it again. And why do I say that
, well I used to work for honda and we worked next door to Nissan. And one of the techs used to work at nissan and remembered my car. He helped me find it. But its been awhile since then. So now Im going to restart this beautiful journey of looking for my draw. Yippee me.
*UPDATE*
The draw only drained my battery to 11.6 volts. But not enough to start my car up. So I tested for any amps and found none. No draw. Kinda confusing. But I have a friend on their way to jump my car off so i can let it charge, and retest this draw. And while im at it, he needs me to look at his Altima.
