IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Wed Mar 17, 2004 10:46 am
anyway, ill preempt your question and assume that your working with two 4 ohm single voice coil subs.
what your going to do is look on the amp for a switch for bridged mode.
if your amp doesnt have this, you may need a "Y" connector inorder to feed both channels of the amp the same signal
now, what your going to do is use a small piece of speaker wire to "bridge" the output channels.
like this-[+] left [-]====[+] right [-]
[==== is a jumper wire]
the wire connects the negative terminal of one channel and the positive terminal of the other channel. this places both outputs in series.
next, take the wires to the speakers. join the two positive wires from the subs together. join the negative wires together.
connect the two joined positive wires from the subs to the open positive terminal on the amp [left positive in my diagram]
connect the two joined negative wires to the open negative terminal [right negative in my diagram]
if your amp is not 2 ohm stable in bridged mode, you will blow up the amplifier.
