Edub1 wrote:This is so crazy it just might work!
I've been looking for a good, cost efficiant tune for my SOHC-T project and have been coming up short - or should I say expensive.
Would it be plausible to hook up a parallel carburator that would open just to feed the turbo? I'm thinking it would hook up just like a second MAF and remain completely closed when not needed. That way I could keep my stock injectors, fuel pump, MAF and ECU. That's about $1000 including JWT tune. The car would have all the benefit of EFI except at say 70-80% load when the carb would open.
I'd also use a BTM for timing.
Anybody see any reason that this wouldn't work?
For all the work you would need to do to make this work, it would likely be simpler and probably cheaper to even add additional injectors in front of the throttle body.
According to Corky Bell, you'ld be limited to about 5-10 PSI of boost, and to a blow-through set-up. As it would be ideal to have a carb throat dedicated for each cylinder, it would be rather difficult to fit such a system in parallel with the existing plenum.
I'll give you a cookie for thinking out of the box, but this would have no benefit over and EFI system and if cost and simplicity is a factor, this is not something you want to get into. Most Carbs are not designed to work under positive pressure and need some level of prep work to allow it to work under pressure. I would recommend reading maximum boost on the carburetion section before thinking about this further. If you're not that familiar with fuel injection, read that part too. You'll quickly realize how much simpler fuel injection is. It shouldn't be hard to find a system that can add an injector or 2 that runs off a boost and RPM sensor. Or if you're not looking for a lot of boost, a FMU would be a cheap and reliable option, even with a higher flow fuel pump.
