RickBlaine »
https://forums.nicoclub.com/rickblaine-u221531.html
Sat Aug 05, 2017 7:54 am
Howdy 240sx-ers!
This week I will replace my original 26-year old water pump (and the three belts) on my 240sx. It started leaking out of the weep hole last week. I bought an AISIN replacement (they are OEM for several Japanese makes) for $42 from Advance Auto (Amazon had them for $34 but I suck and did not check first) and it comes with a paper gasket.
On the numerous threads here (and on YouTube) on water pump replacement, everyone seems to use the Permatex liquid gasket sealer to create a bead around the pump. What is unclear to me is should I use the paper gasket that came with the new pump, sealer only, or both sealer and gasket?
Lastly, Is Peak or Prestone brand still OK for our cooling systems. I do a drain and fill every three years- but six years ago I removed the engine block plug too. It has been maintained so I think a drain and fill will suffice- but wanted to know if any manufacturer changed their formulations that made them now incompatible for our older rides.
I appreciate any advice here.
Thank you!
