Panel Removal
ATL240
Car: My car, flying, sound
Hey I was wondering if any of you out there with a 240SX Fastback knew or could direct me in the right direction as to how you remove the panels on the walls on the sides of the back seat. I am interested in seeing what is back there so that i could possibly throw a sub there. I have seen someone do it on a s14 but i would like to know if it is possible on the 240sx fastback.Thanks for your time and any information you could provide.
:ylsuper
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
You have to remove the back seat first. There are two pull-tabs under the bottom of the seat. When the bottom is off, you can get to the bolts that hold the hinges against the wall. From there its visible screws and hidden clips that release if you pull the panel away.
ATL240
Thanks very much I plan on doing it once the storm blows over.
SpeedRacer1
Car: 1990 240SX, G35
The car should look something like this. The upper back seat thats held on by the hinges is also connected to the carpeting of the trunk. There are like 8 clips on the panals on each side.
