niboce »
https://forums.nicoclub.com/niboce-u196564.html
Tue Jan 10, 2012 7:42 pm
Joe,
I did not work. I had to return it. I got the Iogear Bluetooth 2.1 USB Micro Adapter with a2dp. I did not plug it in to a pc. I just opened the box and plugged it into the car usb port. The display said "Reading" then said no connected device.
It looks like its trying to mount it as storage.
What went wrong. Any thoughts? Is there a specific usb bluetooth adapter I should try. Maybe a firmware upgrade or patch that the dealer needs to do. FYI. I did plug in a usb flash drive and the car mount it fine. It said no song found since of course there was no music on it at the time.
Im not sure what else I can do at this point. I don't think an FM transmitter will be any good unless you can recommend one to try.
Thanks!
