painting valve cover.
clutch Kick drifter
Car: 1992 Nissan 240sx/ Blacktop SR20det
I am going to paint my valve cover and was wondering if i can reuse the seal that is on there or if i got to buy a new one??
partymonster 975
Car: 03 Maxima SE, 94 Corolla
It all up to you if you want to get a new one go ahead but if you want to save some money just reuse it. if it in go shape reuse it.
wannawangan
Car: FOR SALE 1993 Nissan 240SX email me for more details
Get a new gasket. Spare yourself the potential oil leak problem and toss the old gasket. Spend the extra bux on your ride. She's worth the trouble! While you are at it, be sure to get a tube of silicone gasket maker. Might as well hit up those cam caps as well.
My 2 cents.
**David
Luke
I've reused my valve cover gasket several times. If you don't have the time to special order one you can reuse it. Just make sure it isn't cracking or falling apart.
spider_slayer
Car: S14 240SX
S13 240SX
i've pulled my valve cover off several times and no leaks (that i know about). jsut make sure there are no cracks and it should be fine.
Vendettaka24
Car: 91 Nissan 240sx Coupe
Speaking of this topic, what kind of paint do you use to paint a valve cover? Where can it be purchased?
NISMOdrift240
Car: 1995 240SX AT 4-lug
Vendettaka24 wrote:Speaking of this topic, what kind of paint do you use to paint a valve cover? Where can it be purchased?
Just any hi-temp engine paint works. Gloss is easier to keep clean. Just like $6 or $7 at any Autozone
574-240sx
Car: Nissans, Toyotas, Subaru
Prep the cover clean if off real good then scuff it up with sand paper, even in the letters. Then put a coat of primer down then a few coats of your choice of paint then add a few coats of clear. Let each coat dry before applying another.
sr20detmaybe
Car: 95 240sx
I took my valve cover of, and spent about 2 hours sandin and prepin it, painted it and let it dry then put some sandpaper on a wood paddle (about a foot long and an inch wide, comes from paint stores) and sanded the paint off the letters, i went with satin black, omg i love it.
da40
Car: 1995 SE 240sx
WOULD not recomend it ...dude just get a new one cant be more the 20 bucks man stop being so cheap
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
its just a valve cover gasket. reuse it with some RTV Gasket Sealant. ive reused mine 5 times now with no leaking once i used the RTV.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Powdercoat FTW!!!
Rosco
Car: 91' SR'ed Hatch
I demand a link to where you can get a SR20DET valve cover for $20.
NISMOdrift240
Rosco wrote:I demand a link to where you can get a SR20DET valve cover for $20.
uh, he was talking about the gasket... not the cover itself
Rosco
Oh damn.....Too bad, I'd be all over that shiznit...lol
