Vahagn23 wrote:My hubcap fell couple months ago, and the black rim looked kinda ugly on my V, so i decided to spray paint it today. It came out looking uglier in white. Is it bad to spray paint? will it damage the rims? Ill get picks after it rains
Well, you generally don't want to paint rims while they're on the car. You can actually fuse the lug nuts to the rims with the paint. A thin coat of spray paint like you've got isn't likely to do that, but yeah... I think you've figured out a couple reasons why people don't randomly spray paint stuff.
When I did this to the Rambler, this is what I started with...
and this was the finished product.
EACH WHEEL COVER took approximately 8 hours to complete. That's 32 hours of work and about $35 in paint, sanding paper, and tape. Doesn't include the drill or paint stripper that I already owned prior to the project.
I had to disassemble them, clean them, strip the old loose paint off of them, clean them again, mask them, prime them, paint them, clear them, unmask, and reassemble. And yes, I spray painted them. Kept the chrome accents, made the bulk of it bronze, and the inner cups are black.
Also, one of the 4 doesn't look terribly good because I couldn't get off all the loose paint that used to be on it. I would have had to have it media blasted, which is something I wasn't willing to spend the $$ on for what I was doing.
You CAN spray paint something and make it look good, but it takes a LOT of time prepping and masking the surface properly. and that's impossible to do while it's mounted. Or while the tire is on the rim, for that matter.
I think at this point you've recognized that the easiest, cheapest way to do this is to just buy new rims.
