phenryiv1 »
https://forums.nicoclub.com/phenryiv1-u12498.html
Sun Jul 11, 2004 1:55 pm
Strip the rims with aircraft stripper before you paint them. Make sure that the surface is free and clear of dirt before painting. Use several light coats, and clearcoat.
Also, if possible paint rims without tires.
If you have access to ao shop heater you can make an "oven" for them, or you can bake them one at a time in your household oven. Heat gun will work as well.
Take your time and they should remain chip-free.
