chmercer wrote:bleh on spending 200+ dollars. i would sand the wheels with 400 grit until smooth, then do multiple light coats of the wheel paint / clear. just do it on a sunny day, it will be fine but space the coats out, they need ample time to dry and it can take pretty long for spraypaint to dry in cold weather.
Thats exacting what I have been doing and my plan was.
Slipstream wrote:If you can, get them sandblasted with a fine grit like glassbead, then primer, coat, then clear coat.
I'll think about the sandblasting but most likely will just keep them as I have been doing by sanding with 400 grit paper.
What do you mean by primer (nessesary)? What kind of primer do you recommend? Also what about acetone? << cant I just use rubbing alcohol?
