b88dragon »
https://forums.nicoclub.com/b88dragon-u90486.html
Wed Jun 08, 2011 7:00 pm
Hey everyone,
So i got a few questions for you guys for those who have ever done their own paint job, this is just an idea I'm throwing around right now and I just want some feed back and hopefully some questions answered.
First off, I have an 07 altima with the white satin pearl paint, and at the moment I want to know what are the steps into doing this kind of paint job.
Reason I'm asking is because I'm a DIY kind of guy, Where i've done my own retrofit, installed a few performance parts, did the window tinting myself, and some small vinyl work as well so therefore I want to take a crack at doing this kind of job jsut so I know I can do it but of course I will be starting off small before I move onto the bigger stuff.
So far from my research, I've found that the parts being painted needs to be sanded, bondo if needed, sanded again using a range of 600-1200 wet/dry girt sand paper, then applying the primer, the base coat then pearl mixture, then top it off with clear coat.
But what I really want to know is from the factory how many layers of primer/base coat was use? How many layers of the pearl and how many layers of the clear coat? If I can find those answer then I know how to tackle this project.
And also where can I go to order the paint product for the base coat? And if the primer and clear coat can be bought at any paint shops?
I found a website called touchuppaintonline.com that sells the primer, clear coat and paint, and wanted to know if the paint already has the pearl mixture in it or is it something separate completely? And if anyone has every ordered from this site before
I might have answered my own question, but I'm still in the dark and just need some clarification on this topic, any help would be much appreciated and I have thought of doing vinyl but I also what to know how to do a paint job as well.
Thanks again for those that took their time in reading this, Hope to hear some suggestions and thoughts into this.
