j-z »
https://forums.nicoclub.com/j-z-u11653.html
Wed May 13, 2009 2:50 pm
wetsand it with 600, and spray directly over that. youre just sanding to scuff up the original paint, so the new paint has something to stick/adhere to. for the chips that are hard to get out with 600 use 400. if that doesnt work use 220, then prime over that. once the primer is dry, sand with 600. i recommend duplicolor all the way. it sprays on very evenly.
for the first coat of base (red), do a light coat. second coat moderate, and same for the third until you have an evenly painted piece. once the base is all tacked up, time for clear. i highly recommend duplicolor as well. first coat is just a light coat. make sure it is tacky before the next coat. second coat, lay that shiit on there until you see white (dont worry it will dry clear). this will make sure that you have a very nice even finish (no orange peel). if youre satisfied with the second coat, then there is no need for a third.
btw, while sanding, make sure you are wetsanding. rinse the piece off really good with water. then use some rubbing alcohol to clean the surface, and its ready to be painted.
