squeefoo »
https://forums.nicoclub.com/squeefoo-u8899.html
Wed Oct 26, 2005 3:34 pm
After doing bodywork professionally for years, and semi-professionally for many more....I can say on your first try you will be disappointed regardless of the heart and determination. There are so many things that can go wrong even if you know about them and take measures to prevent (temperatures, spray techniques, drying times, sandpaper grit, sanding technique, compatability of substrates, and many many more) The paint is really expensive and requires a fine touch to do even with the utmost care. Get some estimates, go with the guys that do the nicest work, don't expect it to match. Park it out in the sun as much as possible, don't wax it for a couple of weeks/month.
I know it's only a hood but it's much easier this way.
Spend the rest on PM or upgrades since this is essentially "found money".
