Painting KA Manifold Can I use engine paint?
Soravia
Car: 2003 Audi A4 1.8T
How do I prep it? Do I need Primer? Do I just clean it with brake cleaner and brush?
Thanks
JeromeS13
Car: 2008 Subaru Impreza STI
You can, but its just going to burn off in a few hours.
-Jerome
Soravia
I was thinking of using paint to secure the cold-weld that I want to use to fill up the holes after removing the Swirl Control Valve butterflies.
JeromeS13
Oh, you're talking about the INTAKE manifold. Then, yes, you can paint that.
-Jerome
Soravia
I'm going to pull the intake apart, wash and brush using seafoam and repaint.I'll also make a write up tp sticky.
