C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jun 20, 2004 10:12 pm
Mine is painted with flat black Krylon. Unless you build up some thick coats, the effects should be minimal. I would explore the idea of a specialized coating as they are supposed to be better at transferring heat. It may stick better as well, considering I chose not to put primer on mine to keep the layer of paint thin. It has rock chips all over, but it still looks pretty much black, even after 2 years.
