Painting Experts
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Okay all here is my situation. I am working on getting my car ready for paint and ran into an issue. I was told by a local paint shop to get epoxy primer for my bare metal spots. But when researching today I found out that you are not supposed to sand the epoxy primer once applied. I currently have the trunk stripped because it was previously rattle canned by the last owner, the roof, and I went through and have all the dings and what not down to the metal. Should I just strip the doors and the rear quarter panels and spray the entire car with the epoxy primer or should I bondo my areas that need attention and rough sand it to the same as the current paint? Or do I also need to invest in a sandable primer? I can get some pictures also if that would help some. Any input is appreciated. Thanks.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
man go to oreillys and get nasons 2k primer thats what we use at the shop spray it and leave it untill your ready for paint. it comes in a yellowish begie like the 14 in my avi. and grey.
mixeds14
Car: 240
etchin/epoxy primer is made for bare metal u supposed to sprayed 2-3 coats of 2k primer n then blocksand to smoothed the area but if its only a few spots 2k primer will do just fine.
ashibah83
Car: 93 SUPA BLACK COUPE
Etching primer followed by High build primer, sand/wet sand
