miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Thu Sep 24, 2009 3:50 pm
Well since i had advanced auto coupons and they had a deal on the special black rubberizing underbody paint 2 for $7, so i painted pretty much everywhere in the underbody where there was none of that special black protective paint, and over any rust.
Steps i did.
I did sand the drums down really good with 60 grit since mine were pretty rusty on the sides, then i took a rag with mineral spirits and wiped them down. Once this paint cures im painting them with chrome enamel.
Also when painting the drums i masked off the studs with painters tape.
My underbody wasnt bad at all really even though theres alot of salt and gravel on the roads here in the winter in PA.
But there was places with the exposed metal without the black protective paint, and then other areas like the axles had rust on them.
also painted up front, lower control arms, underbody etc, like i said, everything that didnt have this coating or had rust.
for the axels and other parts than the drums, i wiped it quick with some mineral spirits and thats all you need, this paint will protect and go over it, its specially made so you dont have to bust your a$$ sanding nooks and crannies.
End result. GREAT and cheap.
sorry dont got befores. but if you look under your car if you live somewhere, where it snows, and if you have 108k miles, you will see what it was like before.
PICS:
paint used
so go ahead, thoughts/comments/ whatever.
