Painted my headlights
SD_M45
Just picked this M45 up a few weeks ago, as with all vehicles i cannot leave it stock. Ive got big plans for this vehicle for my 2014 build and this weekend got started with my first mod.
Colormatched headlights, took a little work to disassemble internal parts but got them knocked out. Will be adding some lighting goodies later but this will do for now.
NycGMONyc
Car: M45 06 sold
370z 09 trade
M35x 09 totaled
Q70S 15
Looks really good :mike
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
clean work :dblthumb:
did you also cover up or smoke the side area that has the 'amber' lighting??? sorry if I didn't describe it correctly :biggrin:
you can see it more pronounced on my signature picture below (it's the outer portion of the headlight) I'm wanting to get that area smoked to cover up the 'amber' color...
SD_M45
Yes, the Side reflector along with the inner shroud are painted purple (My color theme for this build)
TXT
Car: 2006 M45 Sport
White and purple is a nice mix.
Do you have any pics straight on to the front of the car?
EniGmA1987
Car: '06 Infiniti M35 Sport
Wow that looks really nice.
SD_M45
Thanks guys
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
I like!
flex128
Car: 2006 Infiniti M35X
looks sick
mr_luv
Looks good did you do anything to the projectors while you had them opened up?
SD_M45
Just painted the inner shroud. I plan to do a Lens swap next time i open them up, was on limited time to mod these.
raysworld718
Official on the white.
Larz
Car: 2019 Q70-L RWD
Great job, mate ! Gives the car a most unique look about it.
TOASTERGOD
Car: 2006 M45
lights look fantastic, it seems your lenses look fine why would you replace them? Also I need lenses and would be interested in your old ones because mine are ruined from the inside and right now I can't afford to purchase new assembles just to get the lens.
SD_M45
The Headlight Assembly Lens are good, i meant the Projector Lens. Plan to swap out to a clear to give them a sharper cutoff and a bit more light output
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
SD_M45 wrote:Yes, the Side reflector along with the inner shroud are painted purple (My color theme for this build)
thanks...great work!! I'm hesitant of opening up the headlamp assembly....I might just have to pay to get mine done...
vasekvi
Car: 2008 Infiniti M45 S
Nice work. I was looking at my lenses the other day and noticed they were fresneled. If I ever get into my headlights I am smoking the reflector and swapping out the lenses. What lenses are you going with? TRS is local to me and I used them for parts on my S2K retros for my last car. Great quality stuff.
SD_M45
Ive heard mix reviews, i didnt measure these oems first (should have) but ive seen mention of E30s and TSXs being compatible.
