Mine was preeety narsty. Got some Extreme Temp flat black manifold paint and gave it a few coats after cleaning it off a bit. Let me know what you guys think.
Before:
After:
Yeah, It really blends nicely with the Rims and Trailer hitch(that doesn't even get used) now.Alfredo24.pr wrote:looks nice. before it looked rusty and did not match the car. Now everything looking extra nice
Thats exactly where i got the idea from ahaAlfredo24.pr wrote:would look nice. miamiheat3332 did something like that. Its in his timeline my-pathfinder-timeline-t553296.html
Doh....only wiped it off really good. I'll see how it holds up. If it doesn't do so well ill just sand it down and start fresh.Densetsu wrote:Any sanding of the rust, or did you just wipe it down?
My hitch is starting to get rust in the flat area where you attach the safety chains; I wonder if undercoating or rubberized coating would work. With my last Pathy I touched up that rust a few times with black spraypaint, but since I didn't clean off all the rust, it just returned within a few weeks.
Yeah, it literally took me 5 minutes to do about 3 coats. Not too shabby at all.patqx4 wrote:looks good man. I doubt it will last too long, but I suppose it's not much effort to respray every so often. nice work
The answer is a coating on the hooks on the chains. Tool dip? Some vinyl tubing? or ???Densetsu wrote:Any sanding of the rust, or did you just wipe it down?
Hmm... that's a good point, I never did make that connection. By the chains and inside the receiver is where my rust is... where there's metal-on-metal contact.Chuck Tribolet wrote:The answer is a coating on the hooks on the chains. Tool dip? Some vinyl tubing? or ???Densetsu wrote:Any sanding of the rust, or did you just wipe it down?
Mine is pretty rusty in that area, but back the trailer in to salt water about 140 times a year. It's just surface rust, so I don't sweat it.
I wonder if anybody makes a galvanized hitch?
If I were going to try to make a rusty hitch look good, I think I'd take it off, sandblast, use a good spray galvanizing, then black Rustoleum.
BTW, I've heard the spray paint from Tractor Supply is REALLY good. Even if you don't need John Deere green or John Deere Yellow. (There's
a local ricer with a John Deere paint job and decals. I'm sure there's story there.)
Chuck
