Thats a good idea and pretty much what I had in mind. Its ironic because i thought this would end up being alot cheaper but I don't think it will be anymore. LOL whatever, as long as it'll last, because iv'e heard to much about the overlays peeling over time.motaman wrote:This may be worth a shot - use the double-sided tape and stick it to the headlight cover before you disassemble it, following the contour of the reflectors. Then disassemble it.
If you want to paint the outside of the housings, use this tape as your mask and paint. Peel off the backing on the tape and stick a paper mask to it if you want to. If you want to paint the inside, use this tape as a guide to locate the tape inside the cover. Then use that as your mask and paint.
Disclaimer: I have not done this yet either, but I would try this method if I decide to paint the headlights.
