williamk10 »
https://forums.nicoclub.com/williamk10-u65624.html
Fri Jul 17, 2009 7:56 pm
I bought the Dupicolor kit from Canadian Tire for $25. Make sure to get the one with a brush as it is much easier than using the spray paint as that will reqiure the caliper coming off.
After you have the wheel off, clean the caliper with the cleaner that comes with the kit. Once cleaned and dry, paint away. Very easy, just make sure you mask the areas you don't want to accidently paint like the brake pad, clips, rotor etc. Let it dry (10 minutes in the hot sun) and apply a second coat. It'll dry to the touch in 10 more minutes, then put your wheel back on.
