silpena wrote:i bet if u wait for the water borne paint to come out. Painting pearl white aspene will easy as hell. Yes, i said it. Water borne paint virtually eliminates streaks and such. idk but man it rocks. The way it cures and sets is crazy. Someone in ur business should know. I'm going to take a water borne class next semester in college that my teacher is offering. Gonna run be 300 dollars and out of my pocket. Financial won't pay it since its going to be a community ed class but yeah check it out man. It should make matching ur color alot easier with water borne paint but its going alot more expensive. If ur going to repaint ur car i'd do it soon becuase urethane paints are going to be gone and illegal by end of 2008 and body shop are going to have to use water borne paints due to epa laws and regulation becuase water borne is more environmentally safe.
waterborne paint is already out. it does somewhat eliminates streaks but it still gets blotchy on a horizontal panel. napa and dupont came down and showed us some of their waterborne paint and we had the chance to shoot it. its pretty trippy cause you can actually pile up two coats with no flash time, and it pretty much covers. its the same on the clear coat
Ice2CU wrote:
The Pearl coat Aspen White paint is a tougher system to paint than plain white or the other colors offered by Nissan at that time. It is a fantastic color though and it is pretty expensive to paint. But I think I want to steer away from the white and go blue with that pearl coat. Or something like that. Any ideas or preferences you have on colors?
silpena, I will have to check out that waterborne paint. It sounds pretty interesting.
pearl coats are harder because they're mostly tri-coats. you have to shoot in three stages (four if you count sealer) base, midcoat, clear.while most shops do single stage on changing color cause its easier and cheaper. if you plan on changing colors its going to be around 2g's or upwards of 3g's when you do tri coats
