Paint on aluminum?
chickentendah
Car: SR20DET Hatch
I need to paint my center vent gauge panel, so it has a smooth OEM-like black.
What type of paint do I use, and how do I prepare the surface prior to painting?
The panel is made out of "6061-T6 aluminum". The surface has a brushed appearance.
i2ice4m3
Car: COUNTERSTRIKE!
just sand it with something like...600?, use primer that adheres to metals, then coat it with whatever paint since it's now sticking to the primer. I think that should work...maybe sand the primer a little too. good luck!
sclick55
Definately sand the primer. Wet sanding will give you the smoothest finish. You can also use a hair dryer to help speed drying times between coats. I would really suggest getting your hands on a piece of scrap aluminum and practicing if you're not confident in your painting skills
chickentendah
Car: SR20DET Hatch
primer, sand, then paint .... gotcha
i definitely need some practice first
thanks!
Don't forget to clean the part with a solvent first. Brake cleaner works good, as does paint thinner.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
use self etching primer
