9899pathfinder »
https://forums.nicoclub.com/9899pathfinder-u195839.html
Wed Dec 05, 2012 1:44 pm
Had some leakage from the lower oil pan of my '03 QX4 as others here have reported from time to time. So I removed the pan in order to re-seal with RTV sealant. There was considerable old RTV (or whatever) gasket material on the pan side so I used a gasket scraper along with Loctite's "Chisel" brand of gasket remover. The Chisel helped to loosen the old gasket alright, but it also removed black paint from the inside bottom and walls of the pan itself. This created a big, slurry-like mess that I wasn't expecting. Anyway, I can eventually get all the paint cleaned out leaving just the natural metal of the pan. Is this okay to reuse or should I buy a new one? I mean, why was the inside painted in the first place?
