In a nutshell.you wont match with rattle can.ashibah83 wrote:use grey build-up primer then look on your vin plate in the door jamb, find the paint code, then go to your local parts store and 1) get one of those useless little crappy duplicolor touch up cans(or 5) OR 2) go to napa tell them your paint code get a quart of color and a clear kit probably $50 and a cheap hvlp spray gun(northern tools, local store, or harbor freight) set up some sawhorses and spray...easy
Sad. They don't have Platinum Blue Metallic/Platinum Ice Metallic for two tone coupe. But they have the Dark Grey though.speedeast wrote:Here ya go, surprised nobody knew about this stuff...
Find your color here (somewhere on page 43):
https://www.duplicolor.com/color_selection.pdf
And then go here and read up on this product:
http://www.duplicolor.com/products/autospray.html
Then go here and find the part number on the list, call, order:
http://usautopaint.com/sitebui...r.htm
Don't forget to clear coat, but that's easy enough to find.
Imo, I almost feel like the dark gray primer might still be too dark...s13_pinoy wrote: I used black primer and Cherry Red Pearl duplicolor with clear. Next time I would suggest using Dark Gray primer instead of black, I'm almost 100 percent certain that the outcome would be almost a perfect match. I plan on trying this whenever I get my rear bumper.
