use something called an adhesion promoter.reyes1212 wrote:okay so im going to go buy the "etching" prier and pain i want. so okay thanks rabbit
yeah... it's not a high heat environment... let us not forget I melted my first engine cover trying to cure it... I can't believe I admitted to that...HareBrained wrote:Hold on guys. Think about this for a second. If it's plastic, it's not a "high heat" environment unless it's a very special plastic (and I don't think it is). There are plenty of metals with automotive paint on lots of parts in the engine compartment, why would it not work on plastic as well. Today's automotive paints are formulated to remain flexible because they're applied to plastic bumpers, hood scoops, etc. Lastly, Dupicolor make an "etching" primer that is designed to be applied over a smooth surface, and it's supposed to work well on plastics because of it's superior adhesion properties. It's really quite simple.
That's what I tried at first, but unless you cure it, it is dull and ugly. (IMHO) Besides, it's really overkill because that cover doesn't get more than 300 degrees (not anywhere close to it, actually)CodeRed wrote:How about the paint meant for painting engines?
I r smrt. I thought this was a different thread. whooops!reyes1212 wrote:Oh...lmao that would be nice mabe down the road if that ever happens.I just wanted to do to my engine cover what KimberKenobi did to hers, except I'm making mine red instead of blue.
