paint can sound!!!
katinkid
Car: 03' 350zr33 red
sounds like a spray can in the front of my engin like a marble or something rolling around at idle... any ideas? i heard something about this b4 but not sure!
thanks
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
does it idle rough when it makes that sound?
katinkid
nope... idles fine, its just there like front of valve cover or crank or something right up front
Vegascorbin
Car: 1990 240sx dirt track race car
Timing chain hitting the timing cover.
Replace chain NOW.
katinkid
you think thats it for sure???? im getting work with belts done monday i can have them do that and whatever else needs checkin as well!
so u think for sure huh?
Hype
Car: 93 240SX SE fb Super HICAS
the car you have listed in your profile is a Z33 but you posted this in the KA section.... I take it you have a 240 also??
Chain replacement not necessary IMHO. Just get those guides out and desludge/replace the tension. Very easy job. Make sure you have RTV and possible a new valve cover gasket. Search for tutorial. gl
ninja edit: deerrrr I assume you have a DOHC KA. For SOHC KA its a slightly different procedure.. search is your friend
-RJ-
Hype wrote:the car you have listed in your profile is a Z33 but you posted this in the KA section.... I take it you have a 240 also??
? that z33 is my buddys car lol
Razi
Car: Moo
He was talking about the OP.
-RJ-
Razi wrote:He was talking about the OP.
lol whoops
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Remove the valve cover than shine a light down along the chain. The guide on the drivers side should have a plastic rail on it. If it's gone then the chain is riding along the metal backing plate that used to hold the plastic guide.
