oldandslow »
https://forums.nicoclub.com/oldandslow-u91390.html
Tue Jul 07, 2009 7:23 pm
I found this in another forum.This guy made his sport seats more comfy.I hope it helps You.
The problem is now solved! Today I found a simple and elegant solution. I took the car to a custom upholstery shop (I called several, to find one that has worked on seats in high end sports cars). While they have not worked on a G37 before, they have done similar modifications on other "Sport" seats (in Porsches) to provide more room. The same solution they have used on Porsches worked perfectly on the G37S.
The G37 Sport Seat has a rigid metal brace in each thigh bolster. It is a plate, about 1 in x 6 in, with a short supporting rod on each end. It is welded to the seat frame, and holds the thigh bolsters very rigidly at a nearly upright angle. If you push down and feel around in the thigh bolster, you can feel this metal brace just under the upholstery. The adjustable thigh bolster bladders also push against these braces, making for a very tight fit - it is rock hard.
The solution was simple: remove the braces. They removed the driver's seat, took the upholstery off the bottom, and just cut off the braces. Reassembled, the seat looks exactly stock. There is no way of telling that anything was done. But, sitting in it is just a world of difference! Instead of the thigh bolsters being rock hard and unyielding, the thigh bolsters are now resilient and pliable, and yield to the pressure of legs and a larger body on them. The driver's seat now behaves and feels like the bottoms of the non-Sport seats, or very similarly to the Sport passenger seat. The inflatable bolster bladders still work, but are just not as rock-hard, since they are now pushing against foam and upholstery instead of fixed steel.
Driving around today was a completely new experience. The seat is now actually completely comfortable, instead of just somethig to be tolerated in exchange for the rest of the benefits of the car. The back bolsters are unchanged, so one is still held in place "Sport" style, but without the confining pressure on the legs (I asked them to look into the back bolsters, but they cannot be played with because of the seat mounted side air bag).
For anyone who also feels the thigh bolsters are too confining, this is a simple and invisoble solution that completely cures the problem (I wouldn't be surprised if Infiniti might start doing this in the future, if they get enough complaints about the seats). If anyone is in the Philadelphia area, you might want to see Accurate Auto Tops and Upholstery, on Route 3 in Edgemont (near West Chester), ask for Mark.
