Paging The DOC on the AVIC D3
mazda2005
Car: 2008 Altima Coupe 3.5 BLACK
I purchased the Pioneer XDV-P6 and to my knowledge the avic-d3 has one ip bus is there any way i can connect the XM adapter Pioneer GEX-P920XM simultaneously with that dvd changer because they both need IP BUS.
Thanks!
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
mazda2005 wrote:I purchased the Pioneer XDV-P6 and to my knowledge the avic-d3 has one ip bus is there any way i can connect the XM adapter Pioneer GEX-P920XM simultaneously with that dvd changer because they both need IP BUS.
Thanks!
yes, you run these in series... if you look on the booklet, they should show you how to connect all of these.. out from avic d3 into XM receiver, out from xm receiver into xdv-p6, out from xdv-p6 back into avic D3
mazda2005
As always thank you for the info, i got a great deal on it a circuitcity and i couldnt pass it up. One last thing does the antenna have to be mounted outside of the car for it to work?
Thanks!
rjdmmfl1
mazda2005 wrote:As always thank you for the info, i got a great deal on it a circuitcity and i couldnt pass it up. One last thing does the antenna have to be mounted outside of the car for it to work?
Thanks!
absolutely not... it can be under the dash... that's where mine is
